LowEndGeek
Android Expert
So as soon as I saw phenom post up an early build of cm10 http://androidforums.com/elite-all-things-root/623514-cyanogen-mod-10-build.html#post6078085 I decided to start on porting miui v5 and try to keep up with the cm10 updates similar to how i have tried to do with v4.
Right now I have a build of miui v5 that is booting but that's about it. i am looking for someone who would be willing to test out some builds incrementally as I get things working. Just know that cm10 is nowhere near ready to be a daily driver but I want to follow it's development and hopefully have a rom to coincide with its release.
Let me know why you want to test, if you are using a backup or your main device, would you be able to give detailed reports.
I also have some other things in the works, and want to start using private tests before releasing. Let me know
Got PA booting
Also let me know, would you rather see me focus next on miui v5 or on paranoid? They are both in the same state currently
Got PA booting
