The term 'faster' is a bit vague, there are a lot of differences in how phones are configured with hardware specs being just one of several factors. The CPU speed ratings are just numbers, so I'd also take into consideration the amount of RAM which has a big affect on how 'fast' any phone operates as far as day-to-day tasks. (With the amount of storage memory being another important aspect even though it's not directly related to 'fast') I wouldn't look at anything that doesn't have at least 2 GB of RAM and 16 GB of storage, and then comparing off of that. Also, just comparing numbers doesn't take into consideration if the carrier or the manufacturer add in their own mix of interface tweaks and difficult to remove apps. Side by side comparisons of two different phones with equal specs but from different manufacturers can often result in a noticeable difference. (Of course if you're doing all your research online that's a lot harder to compare.)what is better, redmi 3s prime, j3 2016, g4 beat or k10(2 gb mt6753)? which phone is faster?
thanks
