Need to DEFRAG Internal Storage ?
Ptlkmxyz
GT-S5360 Gingerbread.DXLE1
When I try to install an app I get an error message to the effect that there's no more space :( I revert to factory settings and all is OK for the first few apps but then the same problem.
When I select Settings>SD card and phone storage> ..... under "Internal phone storage" it says Available space = 26.44MB which is more than enough to accomodate another app
I need to DEFRAG but according to the experts, there's never a need to do so with Android
I managed to download Android SDK onto my PC and run adb utility, so new apps are installed on the SD card ..... so problem kinda solved, but how come I have 26.44MB available but can't install any more apps directly to phone
