I am trying to figure out how to deodex my phone so I can run deodex themes on my phone. I have done a good bit of searching and can not seem to find any answers. I am rooted with DJ05 update and the 1221 kernel.
Any help would be great....thanks.
Do you know what rom you are running?
DJ05 super clean 0.9 Rom
you are good to go for themesThe superclean roms are deodexed already.you are good to go for themes
Tried to flash this theme and it got stuck on the samsung logo on boot up. I think it holds on the samsung logo for a bit but waited 2 or 3 min and still on logo....does this seem right? What would make this happen....any help woiuld be great....Thanks......![]()
if im not mistaken that is a dio1 theme?
im not on a computer to check...but it might be and thats the issue
I think you are right so I flashed the one that is similar (here) but is there any way to get the circle accurate battery on to this theme....that would be awsome.
Thanks for the help nitsuj and david...nice to have members like you to help out those of use that are in the semi rookie stage.
