Root Need to hard reset
bezerk19
Okay I'm having problems again with my Wifi, last time I got it fixed i believe was due to a hard reset. However, I'm not sure if i should reset, I might just get a replacement at Verizon because of the WIFI problem.
So far, I've rooted, installed clockwordmod, voodoo, removed (just moved to SD Card) bloatware (de-binged) and used a new boot animations My question is, if I was to do a hard reset, would it erase everything I've done? Ultimately, it would be nice just to wipe everything out since I'm taking the phone back to verizon for a replacement.
Any input? Anyone done this yet?
Well I did a hard reset, FYI, it doesn't remove root, but it fixed my WIFI
