DemDog
Having some battery issues that seem to be coming from a "bad" phone. Talked to VZW today and they are sending me a replacement (refurbished) phone. But before it gets here I want to try and do a reset of the phone to see if that may solve my problem.
Question is do I have to uninstall all my apps on the Rezound and then reinstall them from Google Play when I have the reset done? Or can I just do the reset and then go to Google Play and they will be marked for reinstall?
Thanks in advance for your help!
