Root need to un root and wipe root evidence
uchi
phones gone and broken itself, half the screen is white and its decided to not make calls and send texts, well sometimes works, mostly doesnt. regardless i need to unroot this thing and clear any proof it was rooted before it goes back to rogers. i used z4root to root it, can i do the same to un root and then do the software repair from pc companion to reinstall the software and get back all the things that were on the phone like timescape and such?
well i used z4 again and after turning the phone sidesways it showed me an un root box, clicked it, and it worked for a minute and then gave me an error, something about a null error, but then it didnt give me the option to un root again, how can i tell if the phone has been un rooted?
Install Titanium Backup and try running it, it requires root privileges and so will not start (shows error message).
I just tested this on mine using z4root (but I didn't get the error)
You will need to reboot after unroot.
makes perfect sense, thanks alot.
