Need urgent help(asap)
I have updated my u8800 pro to ics(through the file downloaded from official site).
The first problem i encountered was: After update every thing was fine but after some hours i couldn't able to make a call
so in a hurry i didn't check my battery level and the space avaliable in sd card and started the process from the first again
now the phone just restarts but doesn't go on further it restarts again and again but doen't go any further
what should i do??? Contacting authorized service dealer of huawei would help me resolve my problem
Welcome to Android Forums, vivekreddyp. :)
That restart of the update process may have introduced a conflict or two into your device's software.
I'd charge the battery fully, then do a factory data reset back to the pre-update configuration. I'm not sure if the state of your phone will allow that, so perhaps a look at the maker's support site will yield a remedy:
Support - Huawei Device Co., Ltd..
Also, we have a section here just for that device, with users who may have encountered similar issues:
Huawei IDEOS X5 (U8800) - Android Forums
Good luck; I think you're on your way to getting it resolved.
[edit] I see The Chief jumped in with the link to our forum area for that device; cool! ;)
