Need very, very, simple barcode scanner
mike9000
I need an application that will 'scan' a barcode with the device camera and 'type' the numbers into an application - like a keyboard.
That's all - the same basic functionality as the cheapest barcode scanner plugged into a laptop.
Is there an application to do this (or a tweak that enables me to do it in a more powerful application) please?
Rgds
Mike
What brand, model and Android version phone do you run, mike?
Most smartphones have a stock Barcode Scanner pre-loaded that does what you ask.
Thanks for your reply.
I may get a Wildfire S with 'Gingerbread'/2.3.
Ideally, I would be able to paste, or otherwise insert the data into an active field in a .pdf form.
Is this possible?
Rgds
Mike
I use QR Droid Private from the Market...and welcome to Android Forums! hope you make this our online resource for adnroid questions and suggestions!!
hi there
i suggest u the barcode 2 sql application.
u can find it at app store also at barcode2sql.com
its free to download and easy to use.
