I do not know anything about tablets, but generally with Android to check if an update is available Settings > About > Check for updates (assuming you have WIFI available or 3g)
Here is the Forum for you tab, but it does not have many posts yet. ViewSonic ViewBook 730 - Android Forums
I checked the first post and followed the link in it. That link says it comes with 2.3 which suggests that if you do check you may be able to get the update.
