Help Needing help!
Needing some major help here. Hopefully I am not right.
I was using my LS720 earlier. I was in an app and it completely froze the phone. I waited and tried everything but the holding down the power button. When I did that... The LG flash screen came up (the one when first power it on. It stayed lit up, but my LED light did not transition from like green and red like normal. It would not get off that screen.
We'll, I looked online about a hard reset(volume down plus power) and did that. That reset it (saw the reset screen and symbol thing) but when restarted it did same thing. It took 15 minutes for talkback to start giving me the intro.
I thought great it is fixed. Logged into Google and started updating apps... To my surprise the FIRST app it tried to install it said insufficient memory. I went to storage where it says internal storage, it says I have 128 MB total storage. At the time I was using over 200 with the bloat ware on these.
Any advice? Had rooted a long time ago (November?) and uninstalled some stock apps (that I knew were ok) and reset the phone removing root. It worked fine for 5 months... I know it wasn't the root from months ago. Any ideas?
