Nesoid and Gesoid problema
tater259
Just got both. I have the eris on 1.5 os. But I cant control it. Has no D-Pad on the screen and in the settings it does not give me the option ? How do I get it to work?
Settings - virtual control settings - hide controls - uncheck all.
Sent from my HTC Incredible using Tapatalk Pro.
Never found it. When the game is booted up. Go to settings this is what it brings up
Gensoid
Enable Sound
Input Settings( lets you asign keys which none give the option for the d pad )
Gensoid on Market
Search Roms
Nesoid
Enable Sound
Scaling Mode
Accurate Rendering
Key mappings ( same as above for keyboard )
Trackball Mode
Nesoid on Market
Search Roms
... did you find that online and get it for free?? The new versions all have it. If you just bought it, you should definitely have access to those options. What version are you running.
