Help netflix and marshmallow
boathead
anyone have problems streaming on marshmallow?
nexus 7 2013. never had issues before; i don't have any other device running 6.0. just wondering. i can go back to lollipop, but would rather not. i've cleared out cache in recovery, and have factory re-set. still with the streaming issues.
I believe the Android app for Netflix is not yet fully compatible with Marshmallow. I've encountered it a few times but not as frequent as yours is as may be the case, and my issue was resolved by a simple cache clearing and app reinstallation. At this point, since the rest of your device seems to be working well [this is assuming that none of your other apps are acting wonky], then it is best to wait for an update on the Netflix app.
Hey there, (Nexus 7 2013)
Yeah i got the problem too. I can't stream longer than 10 seconds, video stops and audio continues.
Full reset my device, and only installed Netflix for a go. But nothing has changed.
I'll get more information soon from the engineering of Netflix.
