Netflix on G Box Midnight
NuDrd
Just hooked up a new G Box Midinght TV box to my TV. Been trying to run Netflix on it but it keeps freezing up. Either not playing at all or playing audio with no picture. System is running fine (WiFi ect.) on the 4.0.4 ANDRD version with the 2.6.34 Kernal version.
Youtube, Facebook and other apps are fine, no issues. Just trying to figure out if there is a setting that is off or some detail I may be overlooking.
Same problem as above. Not cool. Just bought this thing, netflix and hulu not supported. App installs but it says device is not supported at launch. Everywhere on the web it is stated these are supported on this device. People left and right are claiming to have these installed and working from Play Store. This is incorrect. Upgraded firmware from factory to what is stated below. Still does not work. False advertising. False reviews. 15 years in IT - Credible source.
Firmware version:
UWS12122012pusa_20130111gbox_ext
Android version:
4.0.4
Kernel version:
2.6.34
Build number:
ICS.MBX.20130111ext
