network data help!!
i have a contract that gives me data (internet) but i am yet to load a single page fully because it takes a ridiculous amount of time( 15mins + and it still hasnt loaded)!! why is this happening??
also on my phone it comes up with a G or a H with a orange and green arrows by the side of it, is this my signal or sign that im using my data on my contract and not wifi?? if so how do i found out how much signal ive got using data like when im using wifi??
the H or g with arrows normay mean you have either 3g or hsdpa conected,.
mmm kinda wierd, try this connect to a a wifo go to android makret download 3g watchdog, it will count you up/don data amount, if it shows up 0% on both after a day or 2 contact your provider as you dont have connection,
also where are you? depending where you are the connection may just be shiz :D no offence intended im not saying your poor or anything mate:o
