scotty85
Extreme Android User
[FIX - Confirmed] Aosp network location fix
anyone else try this? i thot i was fine,but turned off gps in location and security and my beautiful widgets weather location turned into "ramsey"
wherever that is,it was 64* there
so first i tried replacing networklocation.apk in gapps 20110828 and wiping cache/dalvik. no dice. so i mounted system r/w and installed it inside system/app. seemed to work at first,but would revert back to ramsey if i changed anything in settings/location and security and id have to mount system r/w and install again to get it to say dayton.
followed the directions in post 10 and still no dice. mounted system r/w again and installed... seems to be sticking so far.
guess ill give it a couple days and see wat happens. soon as i go somewhere else,ill see if it changes.
just curious if anyone else had any success.
