Help Network mode options
danish737
Im using galaxy s5 SM-G900F which is a LTE model. The problem is im not getting LTE option in network settings mode. Its showing WCDMA and GSM
Hi, can I assume you have a 4G sim card installed, and on which network? Possible it might not be enabled by your network provider. Phil
Yes it is installed.. It's zong network in Pakistan.. They have launched 4g Lte 2 days before..
Although I had installed the 4G sim, and the network was broadcasting 4G, my card had to be enabled by the network before it would connect to the 4G signal. Phil
