Help Network Signal dies
I bought Samsung Galaxy Y from Thailand. The phone works perfectly fine in Thailand. Once reaching Bhutan, it started to give problem with network signals. Since reaching Bhutan I have had the trouble of the signal dropping out alltogether. The signal strength bar can be at the top level then it just drops to nil and the circle comes up with a bar through it. I have to restart the phone for it to recieve or send anything. I tried to reset to factory settings, yet it does not work. As suggested by some, I tried registering to network, it also does not work.
There are same brand and specifications of mobile in Bhutan bought from thailand and it works perfectly fine. The problem is unique to this phone only. I tried to send back to Thailand, but got the reply that the phone is just fine and it again works in thailand....but it continually gives the problems here in my country (Bhutan). Pl. help..........
