Hey all, I recently received a new 190mAh battery for my Lucid. I've noticed that my battery life is 1/2 of what I got on the included 1650mAh stock battery. I'm running CM10 with Min/Max Clocks at 192mHz/Stock 1.2GHz or 1188MHz. Any suggestions?
Hey all, I recently received a new 190mAh battery for my Lucid. I've noticed that my battery life is 1/2 of what I got on the included 1650mAh stock battery. I'm running CM10 with Min/Max Clocks at 192mHz/Stock 1.2GHz or 1188MHz. Any suggestions?[/Q
Oem battery ? I got an aftermarket 2120 mah battery and it worked way better than stock
Where'd you get a 2120?
Also, that site, uoften looks super sketch. Are you sure that battery is really 1900 mah? I've never seen one that big.
I didn't get it from there, I just used that site as a link to what the battery is. But I re calibrated the battery and all seems well now, about 20% longer, which is what's expected
I got mine from eBay. Calibrated via Advanced options in Recovery. It's the same size as the stock battery.
Do you have a link? I can't find a quick one.
And how long did calibration take?
Says its 1920 mah
I've researched battery stats.
-charge to 100
-erase stats
-discharge completely
-charge
but on that last step, do we charge the phone on or off?
Says its 1920 mah
-charge to 100
-erase stats
-charge
