Help New and I need a help
krled
Hello
I hhave ZTE blade and can't add diferent rring ttone for diferent contacts. I tryed thhis using contacts menager that come instaled on the phone. If I need to change something plz tell me.
P.S. sorry on my bad english.
What do you mean you cant? How are you trying to do it now? All you need to do is go to your People/Contacts app, hit the person you want, and select their ringtone.
I have just contacts app. when I hhit the person I have option to edit contact but there is no option to change any ring tone.
one way to do it is using ringdroid... i know when you create a ringtone it gives you the optino upon saving it to set as default or for a specific contact. try that maybe?
Hello
Not sure if your menu system is like mine on my Droid X, but I will try to lead you through the process of assigning a particular ringtone to a particular contact:
1. Push the contacts button to open up your contact list
2. Select the contact you want to change the ringtone for
3. Push the menu button
4. Select "Edit" from the menu that pops up
5. Scroll down to the bottom of the contact info screen, just below where it shows the contact's address
6. hit the triangle that is next to "Additional Info"
7. scroll down to the bottom where it says "Call Handling"
8. select the option that says "Ringtone"
9. From the pop-up menu that shows up, select the ringtone you want to assign to that contact
10. Hit "OK"
11. Hit "Save"
That should do it for you, I just went through the exact same process myself in order to make sure all the steps were right.
