New Android Games Portal Needs Help
ArcadeBB
Hi,
I just started a gaming portal for android and could not get hold of Nexus One as it is out of stock at this moment.
I would like to seek help from Nexus One Owner to see if the games are playable and if it will go full screen.
Also if you happen to find a game that is not optimized for Android, let me know so I can remove it.
My site titled "New Android Games" is at Android Games - Free Mobile Flash Games for Android
Thanks
ArcadeBB
I play darts (which isn't very fun) and the railroad game (which was extremely addicting) and both worked full screen with the N1. It was a bit confusing because it says tap to play full screen but then gives you resolutions undert that screen. I will try and get to the other games also.
Thanks Mostly Harmless. It's great to know the full screen works on Nexus. I wasn't sure earlier so that's why those resolutions choice under the games.
