Accessories New Battery and Screen Protector
I'm looking to upgrade my Droid X a bit, as in protect the already (very slightly) scratched screen, and to add some extended battery life while I'm at it. I see batteries going all the way up to 2600 mAh, with the stock being 1300 I believe. However, I keep seeing horrible reviews for the 2600, and only see decent reviews for the 1800. Note that I do NOT want the battery to stick out more (if that happens with any, not sure), I want it to be the same size as the stock battery. As for screen protectors, I just want something nice and invisible, anything that doesn't take away from the screen quality and protects is what I'm looking for.
Can anyone recommend either of the above through their own experiences?
For your screen protector, take a look on ebay there are alot of different ones on there and they are farily cheap. I get mine on ebay all the time, as far as your battery you could look around ebay also.
