Hi
I recently obtained a replacement battery for my Galaxy Epic Touch 4G and for some odd reason when I power it with the new battery none of my apps are freely accessible, although they are functioning normally. To elaborate I am able to use my task killer from the top bar, and my messaging app gives me messages, but my Home screen is blank. If I try to select the Applications icon I either get a loading circle or just the Applications icon changing to Home, otherwise nothing changes. I am however still able to use the other 3 main buttons (Phone, Contacts, Messaging).
I've tried everything short of hard resetting cause I don't think that would help, as it always works with the old battery and never works with the new one. I searched as much as I thought I could over the web to see if someone else had this problem, and frankly I'm stumped as to how a different battery could cause this, any speculation or advice would be greatly appreciated.
The replacement battery I'm trying to use is the Onite 1900mAh rechargeable for the Galaxy S2.
Thanks
Thanks
