So before I start, let me say that I have tried this on my wife's Vibrant and my own captivate I get a lock immediately in google maps.
After seeing skyhook in the LbsTest settings I decided to look further into what skyhook is. I read the article below:
Samsung to Put Skyhook on Mobile Devices - Midmarket from eWeek
So I thought hey... there are lots of wifi networks around where I live I wonder if it would help if I turn my wifi on.
I get an almost instant lock accurate to 50 meters (good enough for navigation). I have tried it over and over and when I turn off wifi, I get an accuracy of 1700 meters. Turn it back on and get accuracy to 50 meters.
It works indoors and out.
EDIT: I just noticed that for this to work YOU MUST HAVE "USE WIRELESS NETWORKS" CHECKED under location and security then turn on Wifi (you don't have to connect to any networks). My guess is it narrows down your location based on Cell tower triangulation, then uses wifi to narrow it down.
Here is a blury, crapy, video I made of it:
YouTube - Fix for Captivate/Vibrant GPS issues using Wifi
Try it yourself!!
***Note: SAMSUNG, YOU ARE NOT OFF THE HOOK; YOU STILL NEED TO FIX THE GPS!!!***
Try it yourself!!
I was not blaming you for anything. Thanks for your input, someone may find it useful. I however live in a densely populated area (NYC) and this skyhook does not work for me, shows me two blocks off consistently. And most of the time, there is no GPS lock at all een with skyhook. None of the workarounds people suggested around here worked reliably for me.
