Help New GMAIL features not working
N
nx01
Guest
I am on a stock Motorola RAZR Maxx HD running Android 4.1.1 and after upgrading to Gmail 4.3, I see no options to to reply, archive or delete messages from notifications.
Well... this is what it'll do (on my N4).
Had a mess about with different combos and if I swipe from the centre of the notification with both fingers in opposite directions it does it.
That works for me too... Is there a way to set that as the default for GMAIL in the notification tray?
Keep in mind that if you're using an app that has a permanent home in the notification pane (like Power Toggles) this may cause other notifications to be collapsed by default and you'll have to manually expand then.
