measure2cut1
Sup Guys,
First, post. Im a men of many forums, I think these communities are great :rock: Tons of info n good times.
Down to business. The reason I became a mem is I'm having trouble with my phone. I believe my phone is "double saving" aka saving apps not only once in the phones memory, but also on my memory card. The phone is a Samsung Galaxy S2. Its also semi new n a bit more complicated than me lol
When I click the MY FILES - APP, at the home and up button are turned off (not click able) and it says: /sdcard. below is a scrolling screen with almost all my apps among other file names. The thing is i didn't save anything to my memory card, nor did i want to.
If i delete these files will I loose all my apps? If its not the programs thts being saved wht exactly is it? I have about a 150 apps. The goal here is to have the SD card STRICTLY for music.
As for the music part I am currently using DoubleTwist. and sync-ing it from iTunes (wirelessly) from my macbookpro w/ iTunes. I recently just picked up a USB to microSD adapter and plan to copy my saved iTunes mp3 files straight onto the SD card then pop it in my phone. What I would really like would to have some type of system where iTunes from the macbookpro syncs automatically to my phone with all data on SD card. (i like double twist and its air-sync but am open to other options/suggestions and don't mind doing the drag files to SD every once in awhile)
PLease help!
PLease help!
