New Nexus 7 LTE
My guess is that they're still hammering out details with Verizon. They're always so slow with these things after all.
The Nexus 7 2 doesn't support Verizon's network, just their Lte network. So Verizon would be a bad decision with the new 7. HSDPA and Lte are supported with ATT and TMO, so they are the money carriers for this tablet!
Verizon's lte coverage is very wide spread, and might even have their lte network in more locations than t-mobile has their hspa network. I wouldn't consider Verizon a terrible choice for coverage, though at&t would probably be the best.
Correct you are, I have both Verizon and AT&T Lte! Verizon's Lte may be in more places, but when you are not in their coverage area you will get bupkis on th 7! AT&T is the best choice because failover the the fake 4G is still there.
As a side note, my Verizon Lte XOOM speed has been cut in half because it is oversold. Eventually AT&T's will too, but because of their late to the Lte table it isn't yet!
What are the chances that I could remove my sim card from my Verizon Note II and use it on the N7?
