New phone, help
The back panel is actually flimsy and very easy to open .There is a notch at the lower side .By just puling the cover with the help of the notch ,the back panel comes out . After opening the backpanel ,you will find the microSD slot and the battery :D .Hope this helps you .
Ofcourse the best way is reading the manual :eek:
Pages 9-15 :D .
