Hi all.
I've just purchased a galaxy ace it's on o2 it has android 2.3.3 gingerbread.xwkpl looking on this forum a few have 2.3.5 I've tried the over air software and it says no update available is 2.3.5 not out yet for o2?
I only have a 2gb sd card so I'm going to buy a bigger one tomorrow hopefully and then root it following the guide in the all things root section
so I can install to sd card. Whats the best app to install once the phone has been rooted to get the apps moved to the sd card? Is there an app thats moves them auto or will i have to move each app once downloaded?
If I root will it stop me from getting firmware updates?
That's all for now.
Thanks
ACD
so I can install to sd card. Whats the best app to install once the phone has been rooted to get the apps moved to the sd card? Is there an app thats moves them auto or will i have to move each app once downloaded?If I root will it stop me from getting firmware updates?
That's all for now.
Thanks
ACD
