New stellar won't charge battery
Gyrobob
I just got a Stellar yesterday. It charges very intermittently. It beeps a lot, and the little charging icon will only show the lightning bolt every once it a while. After leaving the phone on the charger supplied with the phone for several hours, the phone was only 25% charged. How do I fix this?
Thanks for any info,
Bob
Where did you get the phone?
Verizon sent it out as a warranty replacement for a Droid that died.
I figured out how to charge it by putting a little pressure on the socket and leaving the phone motionless for a few hours. There is a loose solder joint or something inside the phone.
I have a new problem, though. The micro SD card with 900 pics on it that I put in the Samsung Stellar is now empty. No pics. For the last two days, the pics were there, and now nothing.
When I try to read the card in an adaptor in the card reader slot in the desktop computer, it says H:\ is not accessible. Incorrect function.
First off, I would return the phone as defective to Verizon, for another replacement.
I would save the card because you may be able to recover the pictures.
Did you backup the pictures on your computer?
