New to Android need help
gavin69
Hi im new to the forum i have an issue with my wildfire. I have been trying to tether my wildfire to my computer but it says i need drivers. i dont know where to get them or maybe i need a program to tether:) any help would be appreciated.
if you are using a usb tether, that could be true. I know that the app PDAnet had something like that (app and computer program) - and your device should have the software to do that somewhere ... online or mine was on the SD card.
Wifi tether should just work, so I'm guessing that's not it.
Hey gavin69, I got some of the drivers when I installed the htc sync software for windows. Then when I installed the sdk manager and installed a few updates of it, I was able to successfully use usb tethering and also internet pass through. I hope this helps.
