New to S6 - General Questions
Lacit1707
Didnt see a general questions type forum for the s6, so figured ill start this..
came from the S4 to the S6 and phone set up seems very different....anyone know if you can change the lower left button from the "task manager" to the general settings info button like it used to be?
they essentially took away a button and made it the task manager when on the old phone you just hold the home button and that brought up the task manager....
The functions of the softkeys are locked in. There are apps that can switch the existing functions between the left and right keys, but barring root, I doubt if you can find a solution. Even root might not work.
thats disappointing...so, only way to get to phone settings is to have the app button on your screen?
also, when in an app, i used to be able to hit the left "softkey" to pull up the app menu/options.... how is this done now?
