Root Newbie ! Help pls
googler1
Ok, so i just got my BH2 Today. And i want to know if i have to root my phone in order to install a rom. If not, where can i get these roms?
And if i do have to root, how and where can i get a samsumg stock 1.6 w/ no twiz? Thanks.
ok this is what I want you to do, Go back to the tmobile store and tell them you hate this phone.
Then wait till july 16th to get the samsung galaxy S.
Or you could go to google.com/nexusone and buy the nexus 1.
This phone has reached its max and I would lie to you if I told you it was a good phone.
If you bought this phone off of ebay or someone else,
then.......
Hello! Welcome to forums! Please look in our All Things Rooted to learn more about Roms and flashing.
ODIN is our flashing program.
Our roms are currently
1.5 stock (which is what you have with a brand new behold II)
1.6 oem update rom (which is what samsung recently gave us, our LAST update from them)
1.6 oem update tweaked rom (which is what samsung gave us, but without all the extra programs)
1.6 no twiz behold II [take5 is the newest one] (which is a user made rom that integrates 1.6 without the touchwiz interface)
1.6 galaxy rom [r12??] (This is the fastest, and best on battery life, HOWEVER it has not vibrate and it does not let you use your 5 mb camera)
Have fun :)
ps, DO NOT FLASH THE 2.1 ROM, its far from ready. Actually it will never happen unless we get source for the drivers, (which we never will)
Dont worry about root,
the roms have root in there
you would have to only worry about installing the RIGHT drivers so your phone can connect to your computer.
After PROPERLY installing the drivers, you go look for the rom you woud like, then you use ODIN to flash it.
In order to use ODIN, you will need to learn the art of setting your phone into a deep sleep, aka "download mode"
Have fun thread searching :)
Yes i know how to put it in dwnld mode . Vol down + ok + end key .
I justneed a link or help on where to find them if you dont mind , thanks .
