i just got a gnote today. it is unlocked and att. im trying to find out what size sim it akes and how to put it on straight talk. what is the process that i need to take?
Which note did you get? If a GT-7000 or a Note 10.1, then it's a normal sized SIM. (I have those two). I don't understand the second half of your question. What is straight talk?
if its i717 a regular sim from att works with straight talk , on xda theres some settings for the apn you can try might give faster speeds but the stock apn settings work fine as well!
