matrixmainfram
Hello
I am in the UK and have just completed the upgrade of my SGS GT-I9000 from FROYO to GINGERBREAD and have the following questions:
1 all the shortcuts, folders and widgets have gone from my homepages. Is that normal with an upgrade?
2 Is there a quick way to replace all my widgets, folders and shortcuts without a long press/shortcuts/applications for every single widget and shortcut?
3 On a different subject, why is it that call recorders do NOT work on the SGS GT-I9000? Do they work an ANY Android phone and if they do why do they not work on ALL Android phones because they are all ANDROID are they not? (Have tried Totall Recall, Allcallrecorder and Callrecorder and yes they record from the phone's mic but not from the line....could always ask the caller to SHOUT I suppose).
4 I use Jorte calendar and after setting my customisation choices it sometime later reverts to all the default settings and I then have go go all through the process again of selecting my choice customisations.
This phone/operating system is annoying.
