staffsmatt
Hi, I've just started using tasker and I think i'm doing something wrong!
I seem to always need an exit task for one profile. I'm trying to set it so that if the phone is on power and there is a headset plugged in then the screen will stay on and the lock (pattern lock) will be disabled.
For this i have created a new profile and added power source > any and headset plugged > any
For the enter task I have Display Timeout > 23 hours and keyguard set off
Without an exit task my phones screen doesn't turn off even when the headset and power are unplugged, am I doing something wrong or is this correct?
The exit task I have is Keyguard set on and display timeout 1 minute is this the best way of doing it?
Finally is there a way to have tasker acive but not have the notification showing (not a biggie but I would quite like to get rid of it...)
Thanks!
Thanks!
still not sure I've got the exit conditions set up correctly though (or at least in the best way.......
