Help Newest metropcs / tmobile 6.0 kdz firmware
viperdink
Android Expert
@db255
thanks. I wonder if it blocks root.
Its still rootable.
I don't use king root.
Just the" all in one tool "
or adb method.
Oh ok, so metro has the 20c update. I thought it was just T-Mobile.
My wife's unrooted stock OG Stylo/Metro hasn't received the update yet.
Time to do the 11 pm "trick" lol
So, can I directly update my phone (that still is on MS631 10J) to this -6.0 kdz firmware- to get MM and then use "all in one tool " to be in Marshmallow and rooted? or I need to get into ur last post?? My phone is rooted.
You will have to reroot and you'll get the unlocked bootloader splash screen. Just install the twrp version you been using. I have a og version stylo so i did use flashify to load the correct recovery. I can restore all my old version nandroids i've saved.
Acctually I was wondering since Im on Lollipop if I should install MS63120c first and then this 6.0 kdz firmware?
hmm i was finally going to flash this but when i click on the kdz it doesnt download...
edit i found another site that has it...lg-firmwares.com...but that site wants me to download their download tool in order to download the kdz...is this legit? - [MOD REDACTED]
eh im just gonna flash the 20b kdz that i have from last time...dont really feel like downloading a download tool to download a kdz...
I wouldn't . it d/l s data to your device with out requesting you approval . that in its self is suspious and. Un acceptable.
edit i found another site that has it...lg-firmwares.com...but that site wants me to download their download tool in order to download the kdz...is this legit? - LGFirmwaresDownloader.zip
so whats the deal with the kdz download from your original post? did it ever work or does it just not work now?
I'm rooted on 6.0 Marshmallow (MetroPCS phone with the T-Mobile .kdz) I got the update notification from T-Mobile about a week or two ago. Is it safe to download it from there, or should I go ahead and flash the .kdz? And my software version is H63120b
dont take the ota if your phone is rooted...you need to go back to 100% stock with no root before you take the ota
That is why you should not use untrustworty sources for your devices fiirmware.
If i were you i'd re install it from the site I shared . Install gogglefix app before rooting if need be. Make sure it works and settles out before modifying. Boot it few times and check out the operation a little .
I'll be around to help if you have any questions. I've been around a little while. lol
Good luck
Good luck
i didnt use an untrustworthy source for the kdz. i used the 20b kdz that i got a while back from the same website that you posted in the op because the link to the 20c kdz that you posted above does not download (and i had no intention of downloading it from what seemed to be a sketchy site). i was able to fix the issue i was having by doing a factory reset...then i rooted again and all of a sudden playstore started working normally
