Nexus 10 Tips & Tricks
I really like the keyboard trick. Didn't know that was possible with the stock keyboard. thanks!
Yeah I didn't know that either. Going to try it out later.
Also, tip #23, Expand your memory. He is talking about using Stickmount and an OTG cable for extra storage. AFAIK, Stickmount is still having problems with Jellybean 4.2 but the dev is working on it.
everybody should definitely check this out. it's incredible article, I spent a long time reading it and did many things that it said!!! as others have noticed the keyboard option is awesome and I'm using it now and I'm also using the Portuguese keyboard.
The app Light Flow Lite is awesome too!
And I'd definitely recommend the triple tap to zoom. very useful for many things!
thank you so much for posting I'm loving my N10!
Chris
thank you so much for these tips. My only problem was that it took so long to read it because I kept stopping and following the tips as I read each one. Just got my tablet yesterday and spending the day getting everything set up for the best use, as well as setting up my husband's user access and training him.
I found that post before I got my nexus (I just got it Friday), and had to do several of them off the bat. Thanks for posting the links.
