Do you currently have that particular 2 year contract plan?Is there any way to get this bloody phone on a two year contract with the $50 plan (value pack) instead of the $60 dollar classic pack?
Ok, that makes sense, I know exactly what you mean. The $50 plan is fine its drawback is only the first 500mb's of data are at full speed, after that its unlimited but at about 200kbs or 2G speeds. that is for one month of course every month that data is reset.Thanks. Sadly, my budget is, how you say, "limited" to say the least. The $50 dollar plan is about as high as I can go. The only other real option is metropcs, and I'm not even sure if their data is better, or if the nexus even works on it. I'm currently on virgin mobile so ANYTHING is an upgrade, lol. avg DL speed is generally 30 kbps.
If you dont talk much they have a $30 100 min plan with unlimited text and web, the first 5gbs at full speeds after 5gbs its throttled to 2G speeds. Thats what im on, if 100 mins is not enough there are VOIP Solutions that people have tried. or just keep money in the account and pay 10 cents per min after the 100 mins. If you can keep it under 300 total mins per month it will cost about $50
Metropcs plans now have the capped LTE speeds as well except for the more expensive ones. And metropcs is a cdma(for now) phone like virgin mobile, so the nexus 4 will not work with them, though if the merger with t mobile goes through it should when they get things sorted.
It doesn't help you with a subsidized phone, but if you're looking at the $50 T-Mobile plan you might consider Solavei. It's $49 for unlimited talk/text/data unthrottled for 4GB. They also have a referral program which can effectively lower this rate. I switched in January and have been very happy.
Yea, I've been looking at the 100 minute plan, but I would be signing up on a 2-person family plan, and the other person wouldn't want the same plan. I've been looking into google voice as an option for the minutes, but I'm not sure if it's a viable option >.<
What are the 4g speeds over at solavei? And do they have a discount when you have a 2 person family plan? Because at t-mobile, I can get the 2 plans for 80 bucks together.
I went through all this with my husband in January. One thing to keep in mind is you don't both have to be on the same carrier. We seriously considered doing one Solavei line and one $30 T-Mobile line (we ended up with 2 Solavei lines.) We tried GrooveIP/Google Voice solutions. On WiFi it was quite good. On mobile data it was too frustrating for us to use. YMMV. We did get an obi100 VoIP bridge to use at home with our GV number and that's been great - it's like having a home phone again.
The 4g speeds are going to be the same as what you'd get from T-Mobile directly. I usually see between 6-9 Mbps download where I'm located. Solavei doesn't do a family discount, but they have their referral program which we decided to gamble with. For every three people who sign up through your link and stay customers they pay back $20/month. I started by signing up my husband and only needed 2 more to get $20 back each month. It's been a good gamble for us.
Can you or your dad pass the credit check and do post paid instead of prepaid?
Cell Phone Plans | Cheap Cell Phone Plans & Unlimited Data | T-Mobile
Not sure if this works on prepaid, but first phone $50 second $30. if one doesnt use much data that may just be your best option.
it looks like you could put your dad on the $50 first line with 500mbs of 4g data add your $30 line + $10 for an additional 2gbs of data and pay about $90 per month total.
I dont know, I use the prepaid side, have not had a post paid plan since att bought my local company in 2009.Ah, I see. I wasn't aware that you could choose seperate data plans. That helps, then. I guess this is probably the route I'll go down. Are there any surcharges/hidden fees?
My understanding is that on the postpaid side of T-Mobile there will be standard taxes/fees.
Can anyone confirm that you can choose different data options for different lines with the new T-Mobile family setup? It seemed ambiguous on their site, and when I played around like I was setting up service it forced me to make all the lines on the family plan the same. (I have a brother in a similar situation - he wants unlimited data, but his wife wants voice only.)
