Help Nexus 5 error
JaredLeto
Hello, im nubie user - android. Nexus 5 is my first android. Now i have a problem. FYI, my phone 's great. No lag no drain battery etc. But sometimes it shutdown by itself. After shutdown, system not responding is poping out. I'd asking to LG center services, power button still good. Then, when i connect to my wifi, things happen again. But when not in wifi connection and cellular data connection, this phone do great. I dunno what should i do now ? Pls help me .. nexus5 latest os updates..
Hi.
If you are still under warranty, you should send your phone over to LG for a repair or a replacement. This is the easy way out.
Now, if you have run out of/voided your warranty and want to get technical, you can try installing custom recovery, backing up, and flashing the stock rom for LG Nexus 5 (you should only do this if you feel like you'll know what you're doing!!).
-Jaron
