are the revised handsets any better than the originals ?
I suppodse it depends on whether you think you have a problem with your original or not?
ok just got my replacement phone today and it is not the new updated version..its the same old version with small speaker holes n loose buttons..this phones power button is even more loose..again the buttons dont bother me..so my guess is the new versions r going to new customers and not warranty exchange customers
My buttons are "loose" but not enough to rattle.
what model do you have? that may make a difference as the black 16gb is more popular then say the white 32gb.
the button on mine rattles when ever I swipe down my notification bar or open an app on the top half of the screen. its a bit to loose.
