Nexus 5 "Insert an SD card before using the camera."
So, i just got my nexus 5 and there is a problem with the camera.
Every time i try to take a pic it says "Insert an SD card before using the camera.".
Im not sure how to fix this becouse the Nexus 5 dosen't even have an SD Slot.
Can someone help?
Do you have an SD card partition?
Use a file manager to see if you have /sdcard/DCIM/camera. If it's there, it might be a permissions issue and you might need to reset is you aren't rooted.
