Chris Vanden Berghe
Hi,
After 14 happy months with my Nexus 5 the screen started flickering/shaking. Please take a look at
for an example. It's actually a mild example, sometimes the bottom of the screen shakes all the way up to the top.
I gave Google a call and they suggest trying out a number of things including factory resetting the device. As I didn't make any configuration changes or installed any new software I believe it's more likely a hardware failure. Unfortunately the device is out of warranty.
Does anyone know what this could be and if it's possible to repair without breaking the bank? Which component would be the most likely culprit?
I live in HK where there are many little repair shops, but would like to understand a bit better what could cause this before heading over to one of them.
Cheers,
Chris.
Cheers,
Chris.
Has anyone gotten any further with this issue?
