Nexus 6p Stuck in Bootloob
My Nexus 6p was stuck in bootloob , i tried wiping the cache and partitions and doing factory reset nothing happened.
Also Tried to Update using adb sideload but nothing change. Downloaded different OTAs
My USB debugging options were off before entering the bootloob
Could anyone please help me with this issue.
Hi Ahmed,
I'm sorry to hear about your 6P being stuck in a bootloop. Did your phone just spontaneously reboot into a bootloop on its own, or did it crash while trying to do something?
It sounds like you've already tried all the software-oriented troubleshooting that I would otherwise recommend. It sounds like your phone may have suffered a hardware failure, and unless your bootloader is unlocked there's not really anything else you can do for it other than to seek a replacement.
I wish I had better news for you.
This happened to me. You will need to flash a new boot image that enables the use of all 4 cores. Head over to xda for the thread on that. Follow the steps, maybe watch a couple YouTube videos on how to flash and you should be fine.
