I had this problem for some 2 weeks before I figured it out. Here is what I experienced, and at the end you will find how I fixed it.
I noticed Android OS using large amounts of battery power, effectively preventing tablet from going to sleep. Usually, the screen would the #1 user of battery, but after an hour of inactivity - with the tablet screen off and all applications closed- android OS would become #2 if not #1 power user.
I googled, tried many things- everything short of resetting to factory settings and nothing worked.
Something seemed to prevent tablet from going to deep sleep and drained my battery rather quickly. Not even using the tablet in "safe mode" alleviated this problem.
By accident I noticed that this would not happen when I traveled away from home. Android OS would be distant last or second to last power user, like it should be, instead of first or second of normal usage at home.
Turns out the problem was with my internet router. I switched it from no security to WEP secure password about 2 weeks ago. I switched it to WPA today and Android OS settled down and stopped using battery at unpleasant proportions.
For whatever reason Android 4.3 really doesn't like WEP security and it is preventing the OS from going to sleep. Hopefully, someone else experiencing this problem will find this information useful and will help them get peace of mind and maybe even some sleep too.
