Erg Raider
Hi all,
at some point my Nexus 7 (2012) tablet crashed and after that started boot looping (not restarting, just dancing dots for 10h++). So I booted into recovery mode, did cache wipe and factory reset, but nothing changed, boot looping for hours was the only thing it did. So I followed a guide to flash a factory image from the PC which failed presumably because of a wrong factory image (yes I did research before, but finally picked the wrong one).
Now after that it stays completely dead and does not boot into recovery mode or anything. So my question:
Is there a chance to reactivate it with any trick?
I would appreciate any tip!
To make things clear:
- It is NOT a battery problem, the battery is fine and has always been until the failed flash.
- All buttons are dead, neither power, power + volume down, power for 50sec, nor anything like that brings back a glimpse of life.
- The PC / Android Development Tools / etc. do not recognize it any more.
- Windows 7 _sometimes_ reacts to plugging in the USB by searching for drivers but then fails. (Before the problem, the Android drivers were working perfectly fine)
The applied installation logs:
C:\Android-adk\platform-tools>fastboot -w update image-nakasig-jdq39.zip
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
archive does not contain 'system.sig'
archive does not contain 'vendor.img'
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8192
Inode size: 256
Journal blocks: 32768
Label:
Blocks: 7339776
Block groups: 224
Reserved block group size: 1024
Created filesystem with 11/1835008 inodes and 159204/7339776 blocks
Block size: 4096
Inodes per group: 7088
Inode size: 256
Journal blocks: 1772
Label:
Blocks: 113408
Block groups: 4
Reserved block group size: 31
Created filesystem with 11/28352 inodes and 3654/113408 blocks
Bootloader Version...: 4.18
Baseband Version.....: 1231_0.18.0_0409
Serial Number........: 015d3b65fc2fee12
checking product...
OKAY [ 0.030s]
checking version-bootloader...
OKAY [ 0.017s]
checking version-baseband...
FAILED
Device version-baseband is '1231_0.18.0_0409'.
Update requires '1231_0.17.0_1205'.
finished. total time: 0.179s
Block size: 4096
Inode size: 256
Label:
Blocks: 7339776
Block groups: 224
Block size: 4096
Inode size: 256
Label:
Blocks: 113408
Block groups: 4
checking product...
OKAY [ 0.030s]
OKAY [ 0.017s]
FAILED
