JohnHwessel
Any of you guys in the UK updated yet ?
Updated on Tuesday. Slow to start with, but factory reset seems to have helped. Still a bit sluggish sometimes.
My Nexus 7 refuses to update. Still thinks KitKat is the newest version. Starting to piss me off. Why can't they make it like iOS and be there on day of release?
I meant for the v1 nexus 7.I wouldn't say pulled but I have read that they are problems and they have suspended the roll out but I think it is just nexus android machines
I had the same experience until I did a factory data reset. I took a full Helium backup first. Once the tablet booted after the FDR, I answered YES re restoring Google apps. It installed exactly TWO apps and then stopped (no error). Once that happened, the tablet was unusable. The lag was gone, but so was my wifi, and this is a wifi-only tablet. This is AFTER the first-boot wifi check, which verified that everything was fine with my connection. At first I attributed this to the fact I had deselected the last two options when going thru initial setup, post-FDR (wifi ON even when not in use, and usage statistics). I reset a second time, thinking that it expects all defaults (figured I could change my selections later). Same thing happened - two apps, and then no wifi! Since the problem occurred after the Google restore of two apps (the same two apps, since it appeared to be going in alphabetic order), I decided to try one more FDR, but this time chose not to let Google restore apps (i.e., setup as new device). It seemed to work, and everything was still snappy and smooth, so I decided to try installing some apps individually. It still worked. Then I took the plunge and installed the two apps that had seemingly killed it before. Hallelujah, everything still worked!I updated to 5.0 yesterday, and how I wish I hadn'tIt is now almost unusable slow, taking an absolute age to open and close apps.
You are one lucky person! BTW. just what is BETTER after the update?Guys, I just updated and lollipop is awesome! Seriously, if you don't have it, GET IT! It's like a new OS in my opinion.
Maybye you can use adb to flash an older OTA update?You are one lucky person! BTW. just what is BETTER after the update?
I've had to do a factory rest and was kinda pleased... for about two days. My tablet slowly returning to brickdom.
How does one get rid of Lollipop and return to a previous version?
(sent from my PC. My tablet surely wouldn't keep running long enough to send this!) lol
Tried that, same deal as the poster you quoted. It didn't help... So now instead of 200 apps I can't use, I now have 40 apps I can't use.It might be worth a factory reset. If that doesn't fix it you can always go back to 4.4.4 using the factory image
Developer mode and limiting background processes to 2 seemseems to be the main advice on the official Google nexus lollipop threadsTried that, same deal as the poster you quoted. It didn't help... So now instead of 200 apps I can't use, I now have 40 apps I can't use.
Terrific! And they call this an update?!Developer mode and limiting background processes to 2 seemseems to be the main advice on the official Google nexus lollipop threads
Regarding returning to a previous version, if you don't mind a factory reset you can use Wugfresh Toolkit to return to any previous (or indeed future) version. When running the Toolkit use the 'Change..." button to set it to whatever version you would like - say 4.4.4. When it tells you it has auto-detected a version error it will offer to correct it - just say "No". You can then use "Flash Stock and unroot" to flash your chosen version. This works to go from 4.4.4 to 5.0 as well - just tell it you're already on 5.0 and then flash as above. (I hope this isn't "teaching my grandma to suck eggs!").You are one lucky person! BTW. just what is BETTER after the update?
5.0.2 is up & running fine on my n7 2012..
