Nexus 7 amazon appstore compatability
I luv trolling
Lately ive been very pleased with some app purchases and free apps ive recieved from the amazon appstore which ive downloaded on my nexus 7. I was quite disappointed that many AAA titles found on the appstore and google play (the big EA and Gameloft games) were no where to be found on the amazon appstore. I headed over to the webpage and was pleased to find thats they were in fact there. as I was about to purchase need for speed most wanted for 3.00 less than what google play sells it for I was greeted by a pop up reading "you may be purchasing an app that is not compatible with your device". what i'd like to know is if it really is incompatible or if I can get away with downloading it. Based on my experience with scribblenauts remix and sonic 4 episode II i'd assume it would just run the game with thin black strips ( non intrusive) on either horizontal side of the screen.
After purchasing it how would i go about getting it installed on my nexus 7? Would it appear on the cloud in the appstore app?
If you have the Amazon App store app installed, purchase it through that and it will download and install once you've bought it. You'll need to keep the app store installed as it's needed to verify the purchase every time you play.
I've never used the Web interface so I'm not sure how it would work, sorry.
What i was trying to explain is that these apps do not appear in the installed market >.< however the problem has been resolved. I discovered the app has also been reduced to only 0.99 on google play and will be purchasing it from there.
