iamthrealmungo
Hello,
I'cve read a lot of conflicting info on the charging times and practises when using the supplied USB cable etc.
I think the supplied USB cable is far too short, but people have said that the supplied USB cable is capable of taking 2A which is unusual, where can I find a longer replacement USB cable of the correct specs to charge the Nexus 7 (2013)?
Also, how long should a full charge take using the mains power when the tablet is just locked with the screen off?
Is it best practise to let the battery discharge fully and charge fully a few times or would it be better to charge as often as possible and keep it as close to 100% as possible?
Thanks
Thanks
