far as i know if the screen is cracked,then the digitiser has to be replaced,mine cracked too,i sent mine to asus with pics and a explanation that i had nothing todo with it,well they repaired it for free,and by the way,theres plenty of youtube videos on replacing it,and its nt a simple task,i would say you will need both once you start taking it apart,dont think it will be that simple,hope this helps
